It is currently Mon Jul 28, 2025 1:03 am
PostPosted: Wed Sep 14, 2005 1:27 pm
This was scary, to me anyway. All I needed was to install my end graft and the side assembly would be finished, ready for top and back. When I got ready to route a groove I couldn't find a bit the right size that would chuck into my dremel or my laminate trimmer so I used my 3 hp Bosch plunge router. I don't recommend everyone try this, although it came out fine, it sure made me nervous. I have since ordered the correct bit. Kinda like using a sledge hammer to drive a thumb tack.
PostPosted: Wed Sep 14, 2005 1:30 pm
State: ON
Hey, if it works.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Wed Sep 14, 2005 2:21 pm
I use a sharp utility knife and chisel. We all have out quirks
john
PostPosted: Wed Sep 14, 2005 11:42 pm
I use a thin kerf Japanese saw to cut the channel and a good sharp chisel to remove the waste. Works ok, but I think I am going to switch to the router method as soon as I get a jig built.Dave Rector38610.3632060185
PostPosted: Thu Sep 15, 2005 1:27 am
a dovetail saw and then chisel out the area. This can be done in about ten minutes.
Robbie O'Brien38610.454537037
